1 - 2 of 58 Posts
Make sure you contact SVCM support too. As you do your test, and additional suggestions by them, you can do those at the same time. If not you might have to repeat something again. When I had an issue, I had to debug and then a replacement was sent.
+1. The code was P0128 when ECT1 temp sensor triggered. Confirm it is the device and not the sensor itself. I had to replace S-VCM once. ALL electronic devices can and will fail sometime in its lifetime. Replace and move on.
1 - 2 of 58 Posts
