Okay guys, I know there are plenty of threads about IAC valves, EGR valves, plugs, coils, power steering issues etc. but I do believe I'm beyond all of that at this point. Need a sanity check please:
Background:
2002 Honda Ody EX-L with 130K miles. Transmission rebuild at 89K. Upper,lower front and transmission mounts replaced at 89K. Starting last summer, when the weather reaches 100 here in central TX for a good number of days. When the van would reach normal op temps and then come to a complete stop (in drive, break depressed), the van would fluctuate from normal idle to very rough/erratic idle and even sometimes die (esp. after coming off a hot run on the freeway and stopping quickly at an off ramp light). But first 5-10 minutes of driving in the morning it would idle just fine when stopped in drive, not until hot would we experience this behavior. We lived with it last summer, didn't seem quite as bad as now. A week ago wife said the car died at a light. Then she got to work and 2 hours later came home and CEL came on. Only code pulled was P0505 (IAC). Well, I took the throttle body off and replaced it with an Echlin brand. No more codes but problem persists. Then I bring it to a local mechanic:
Hooking up a Snapon Modis computer he didn't find anything but a past misfire on cylinder #5. He also checked the P/S harness and wires while another tech watched the computer and no loose or bad connections there (there's a TSB about this but it includes an additional code to the P0505). He then pulled out cyc 5 plug and immediately said my plugs are past life (I put in NGK single platiniums at about 70K miles). Then he inspected the cylinder and found excessive carbon deposits and suspects the valves have pulled in some and need adjustment. His recommendations, change plugs (which probably won't solve the issue) and then perform a valve adjustment (4 hour labor job).
Also, last thing I checked just because it bothers me that the van idles fine before it gets to real operating temperature (i.e. first thing in morning and the first 3 miles with plenty of stop and go, she idles just fine), I checked the ECT (Engine Coolant Temperature Sensor (not sender, though my model may be both the sensor and sender, but I know for sure it was the sensor I checked). With the car off for several hours, still a little warm the resistance was 450 ohms and then after the car got to normal op temp the resistance was 250 ohm, which I believe to be a good operating thermister?
So, valve adjustment seem correct, thoughts?
Thanks
Background:
Thanks
