Just finished replacing the timing belt and the 2 bent valves all that caused. While putting the throttle body back on my ratchet came back and tapped the positive battery post while putting the top left throttle body nut on. One of those times when you forgot you had the negative terminal back on.
Well, I didn't think anything of it but now when I try to start the car it just turns over and doesnt fire. Computer is throwing P2176 codes which has to do with the throttle motor. OBD tool reads 0% throttle position when its trying to start so it seems like I fried something. I couldn't find a specific fuse for the circuit but did a quick glance with a light at all the fuse panels and didn't see anything blown.
Should I just go to the junk yard tomorrow and pull a new throttle body?
