1 - 6 of 6 Posts
Little Bob said:
Does anyone know if I have to replace the entire motor assembly or can I I just replace the broken cables? I did some research and it's not looking good for a cheap fix at this point.
I think you should call the Stealership service dept. to get some idea then share with us. I like to know this and hopefully its a cheap fix. GL!
The sliding door's inside panel shouldn't have to come off, just the interior plastic panel under the windows in rows 2 & 3.
Correct. Also like to add that the motor does not need to come out to replace the cable. You just need to remove the front cover on the motor, held in by 5-6 screws.
1 - 6 of 6 Posts
