Before tearing into my 2012 Ody to figure out what's broke, I wanted to see if my symptoms pointed to a specific problem. My driver's side sliding door begins to open then stops when the center trolley is almost around the bend (door about 3-4 inches open), then it stops and gives the 3 beeps. It does this when using remote, door buttons or outside handle. Door will not close other than manually after this. My first thought was a likely problem with the wheels on one of the trolleys, but they all appear to be rolling and I haven't been able to locate any obstructions on the top, middle or bottom tracks. I cleaned and greased them all to no avail. Cable appears to be in good shape, also. Does anybody have an idea what may be causing this?
