Having a problem with my drivers side sliding door. Here is what happend. We started getting the "beep" that you get when you are in reverse or drive with a door open, hearing it constantly while we were on a trip. I tried to find the problem, but had to do something, so I figured I could pull the fuse for the buzzer, there was no fuse position listed so I just started pulling out fuses one by one. After many fuses the buzzer stoped, and to my suprise it didn't start back up when I put the fuse back in. Cool! So we could keep on driving, except when I tried to use the lt sliding door it don't work! Rt one works fine just the lt is inop. I looked around the web and tried the different resets with the switch to the lt of the steering wheel and the fixes by pulling the #13 and the 40 amp fuse under the hood but no luck! anyone have any other ideas? It is a 2005 touring.
Thanks for any help
Brett
Thanks for any help
Brett
