I've spent a long time searching but can't find anything related directly to my issue.
2007 Odyssey EX. The passenger door when opened electrically keeps pulling after it should auto-stop when fully opened. The door beeps three times when this happens, and I can tell the door is trying to be pulled past the fully open position, the door/motor makes a noise as it works hard. Most of the time the door will close when the button/handle actuates the door motor, but sometimes I have to turn off the sliding door switch, and I can see some tension released from the door, when powering the door back up it usually will close with the motor but sometimes I have to turn the power back off and close it manually.
Tried the door reset protocol of pulling the fuse, opening manually and closing right then left doors with the motor but no improvement.
I feel like there is some sensor that is not sensing when the door reaches the point where the motor should turn off.
Would really appreciate any help.
Thank you
Thank you
