Slipping belt
388 Views 6 Replies 5 Participants Last post by  gizzo20
Have an 07, 200k miles. Had a power steering fluid leak and the belt slipped off and busted in the process of getting the line fixed. Figured it was the fluid making it slip so I cleaned off everything before I put a new belt on, in addition to fixing the leaking line. Im on my 4th belt and a new tensioner and it’s still popping off then shredding within a week of putting a new belt on. Anyone else had this issue or have any thoughts on what could cause it? All help is appreciated.
1 - 7 of 7 Posts
How many miles are you getting out of each belt? You have at least one pulley out of alignment. Carefully watch, maybe even record a video of what's happening along the entire belt drive while the engine is running. Check for play in the pulleys if the belt is off. Check for belt wear/fraying after each test.
Reactions: 1
1-200 maybe. I’ll try the video and see if it helps see anything that is out of whack. I can’t remember where I saw it but someone mentioned that when installing a new tensioner to to tighten down the main bolt before the smaller one. Might have to take it apart and try that too.
Tensioner bolt bent?
Shouldn’t be. The old one I took out was in pretty good shape and the other has very little use so far.
Be sure to check the harmonic balancer rubber coupling on the crankshaft pulley. It can cause wobble to give belt failure.
Reactions: 2
Don’t have an answer for your belt issue.
But….
I would check if any of the power steering fluid got behind your timing belt covers and onto the timing belt. I had my high side hose pop spilling fluid everywhere but never thought to check the timing belt. Then last weekend I found that the belt was all cracked and had a sheen to it. There was also a tar like substance all the way at the bottom by the crank shaft. I’m pretty sure that it got soaked with power steering fluid when the hose erupted a year ago. Take the top cover off first to check. If your belt looks shiny or wet, then you might want to take the bottom cover off too. You will have to remove the crank shaft pulley to get the bottom cover off which can be a difficult task without the right tools. Putting it back on is even more of a challenge. Have to torque the bolt to 181 ftlbs. If you have a scope camera then maybe you might be able to snake it around the belt to see the bottom.
If you haven’t done the timing belt yet, now may be a good time. If you’ve done it recently, then more of a reason to check it for PS fluid. Don’t want it to fail prematurely.
See less See more
1 - 7 of 7 Posts
