Hi,
Today was buttoning up the front fender cover noticed oily leak under plastic cover in front of the driver side wheel. What could be there ? Looks&feels like engine oil, but could be anything.
Recently (about half year ago) I had to replace transmission cooling line at the bottom front (it rusted out). Looking in the hole in the plastic I see some oily metal pipe there. What is it, I could not find a diagram.
Could be power steering return line? Is it routed that way ?
Try putting a clean white paper towel. Check if just one color, mix. It could be ATF leaking under cowl and dripped in that area. But if you pop the hood, is there corresponding wet area? For me driver side leak right below the wheel was coolant when radiator seem cracked.
