Hi,
I own a 2000 Honda Odyssey EX with 164,000 miles. The other day I noticed an oily substance caked around a hose in the engine compartment, as if there was a slow leak of some sort. I cleaned up the area in order to see if there was a leak and now some oily fluid is back. I attached a couple of pictures and the hose goes into the power steering fluid reservoir. Is this a power steering fluid leak? Does anyone know how easy or expensive this would be to repair?
Also, my Odyssey transmission has been having issues for the last year or two. Shifts from 1st to 2nd are rough, as if it holds 1st gear too long. Shifts from 2nd to 3rd aren't as bad, and 3rd to 4th shifts are normal. KBB says the car is only worth maybe $4k but probably closer to $3k. I change the transmission fluid every year because I heard that can help the transmission last longer. Since the transmissions are weak for this model year, should I just sell the van now while it works or drive it until the transmission dies? It's not my primary vehicle anymore, just use it for moving large items and things on the weekends. The transmission has been having issues for a while but the van runs fine. And there is a loud clunk when I drive in reverse...one clunk and then it sounds normal. Not sure if that's the tranny again or something else. If any of you have any ideas or recommendations, I would really appreciate it.
Thanks,
Nathan R.
Thanks,
Nathan R.
