I have a 2010 EXL. I’ve already disconnected the ANC harness under and to the right of the main passenger side glovebox. Doing that took care of most of my problems relating to upgrading the speakers and adding a powered subwoofer. In other words, I no longer get any strange, erratic sounds from my sub. But I still have one last annoyance: Even though the ANC module is disconnected, the factory radio apparently still is sending out an ANC signal (albeit inaudible) to the speakers. At least I assume this is happening due to the fact that my powered subwoofer, which is set to come on only when it detects a signal, comes on as soon as I set the car key to the accessory position—even with the radio off.
I pulled the radio head unit out, but I have no idea which, if any, of the harnesses are sending out a “blank” inaudible ANC signal which my subwoofer is “hearing.” Does anyone know the correct harness to pull, or have another solution. Thanks in advance.
