Nice work Dorhn!
Just plopped your data in excel for you..
The low volume and higher volumes followed the same trends, so just plotted one set of data.
The graph of the in phase measurements are telling. You're getting LOTS of dropout in the 60-140Hz range. This is in part due to the cancellation we were talking about, but also likely due to the location of the rear speaks and that of the SPL meter. Given the length of the passenger compartment, frequency/depth of the dip, and location of speaks vs. SPL meter, I'd say node.
Ultimately, what you decide in terms of how you end up configuring your rear speaks comes to your own perception of the sound. Here's my guess on subjecively, how the different setups sound:
0 deg (in-phase): excellent transient response and attack, low end fullness, time-correct phase perception, lack of mid bass warmth.
180 deg (out-of phase): punchier mid-bass sound, transient response compromised a bit, sense of slight "delay" on certain bass passages.
And how I might look at it on a music preference/recommendation standpoint:
The 0 deg case would be better for the purist, listening to acoustic music (classical, jazz, etc..), where coherence is most important.
The 180 deg case would be better for those looking for a warmer sound, and higher output. Rock, pop, rap, etc...
Now, I think for the 180 deg case, you need to get those speaks crossed over @ 100Hz or lower, else it will sound kinda weird.
Seeing that Marley disk, I really can't make a good judgement on what you would prefer. Marley is kinda middle ground... (or all over, depending on how you look at it!)
Anyhow, time for bed. Thanks for posting this data Dorhn! Great job! This is really loads of fun too!
Oh, and on the topic of NVH, I'll have to chime in later. I could write alot on my thoughts re: this subject (used to do NVH analysis back at Ford when I lived in Michigan, believe it or not!)... I've read the other threads on this subject, and don't wanna start another huge chain of discussion in the A/V, Sec, Navi forum...
'nite!
-SJ
p.s.- you should get a copy of the Autosound 2000 CDs. I used to use Stereophile's but I really dislike the warbles. The AS2000 has pure sine waves....
DEP '01 EX no-navi
[This message has been edited by shinjohn (edited 11-04-2001).]
