Hello,
I need some help. I have a 99 Ody with 140k. Here are my concerns
1. speedometer not working
2. Cruise control not working
3. Check Engine light is off
4. Scan tool indicates
"no codes"
"no pending codes"
5. Typical "hard shift into reverse" once every 10 to 20 times
6. Seems to shift okay.
7. Odometer & trip meter work fine
Can it be a Vehicle speed sensor? Holidays on the way & pending layoff. What could it be??
Help!!!!!:confused: :confused: :confused: :confused:
found problem with speedometer
Okay, here we go.
The cruise does work. The indicator on the button does not light up, the dash "cruise" light lights up & it works fine.
I called the previous owner & he said that the speedometer went "nuts" and it spun around.
The speedometer needle is under the pin that prevents the indicator to drop. It sounds like it did a "360". I noticed it does move upward when I drive, but the plunger needle is preventing it to go further up.
I was wondering if I took the cluster apart and manually move the needle back, would it be fixed?
Anyone else have this issue.......
