is the check engine light on? if it is on and the code is for vss. replace the veicle speed sensor. they go bad from time to time. poss. the same as a accord
Thank you, the chk eng light is on and I haven't had it checked yet. However, the light came on after I put Seafoam in the engine to get rid of carbon build up and the speedo went out after that? Is the vss easy to replace and where is it located? Tranny? Thx
vss is on the back side of trans, by were the rear engine-trans mount bolts. it has 3 wires connector and to 10mm head bolts
