I've searched on my particular issue, no luck. I replaced my rotors and brakes in August. In the van the other day noticed a high pitched squeal coming from the front. It's pronounced at low to medium speeds and stops if i pump the brakes. It also is pronounced when turning. Are the two related? I need advice diagnosing the problem.
Thanks
Since this site is a great place to find answers I thought I would share a solution I discovered while troubleshooting the above problem.
The source of the squeal turned out to be a brake shoe clip that had slipped a bit and was rubbing against the rotor. After pulling the shoe and a quick adjustment of the clip, the problem stopped.
