I took my '03 into a Honda Dealership to have the SRS unit replaced under the recall (all other recalls had been done by another Honda Dealer), and nothing else done (they said they had the part). Long story that I posted about several months ago, and when they did not do any replacing of anything, I got the Ody back and they told me I had two SRS codes (I knew about the 'internal failure code' and the SRS light was on before I brought it in) and that second one was a code for the front passenger airbag and/or seatbelt retracter failure or similar and that it would cost me X amt of dollars for them to troubleshoot it. I informed them that the only reason I had brought my Ody in was for the SRS recall replacement and that is all.
They also said that nothing they had done could have 'possibly' caused either one of those codes.
Several weeks later when they assured me again that they had the new SRS unit and would install it under the recall, I went back and they informed me that all they would do was replace the SRS unit and nothing else and that the SRS codes would not be taken care of. I said fine, I would deal with any codes later.
Low and behold, after the installed the SRS unit, the SRS light went out and I used a friend's (mechanic) pro scanner and it found no codes.
So, YES, I think THEY caused the problem, but a simple reset may be all you need. If the problem is still present, then there is actually a fault, it must be death with to ensure that any airbags will be deployed when needed.
SO, I do NOT have much faith in Dealers when it comes to much of anything, period.
To me, they instruct their workers to get any dime out of you they can by causing problems and selling you unnecessary services and parts.
Whew!!! :ahh:
Buffalo4
