Just upgraded the bushings on my 2013 Odyssey Elite. Should work on 2011 through 2017.
Garden tool Street light Tool Musical instrument Metal
Automotive lighting Hood Fluid Liquid Rim
Plumbing valve Gas Automotive tire Nut Machine
I went with the Mevotech end links. Part # TXMS60845. Which are way thicker than stock. Plus the have grease fittings for longevity. Mevotech does not make the frame bushings so you will need to go with someone else for them. I went with Moog. Part #
K201620. Supposed to be made from a stronger material than stock. They have really made a difference on body roll. I bought mine through Rock Auto. The links were 37.89 each. And the frame bushings were 6.78 for the set of two. Definitely recommend this upgrade.
2016 Touring Elite
Nice! Are there end links only for rear or does front have them also?
There is no rear swaybar on the 4th gen Odyssey. Those are front links.
-Charlie
