1 - 13 of 13 Posts
My ody starts then shuts off immidieatly after. Doesn't matter if it's after driving it a while then staring it or after starting it first thing in the morning. This started yesterday when I was at lowes. I started it turned out of my parking spot, got a couple of feet and it stalled.It would start then shut off afterwards. It wouldn't even get to idle speed and throttling up had no affect at all.It did eventually start after 6 attempts. Anyone ever experienced this?
lower tube seals huh? i gotta get that looked into. another thing is i am pushing white smoke out my tail pipe and some other friends said that it could be my fuel filter. i dunno i need to be more mechanically sound. :(
whoa.... ok starting then shutting right off? check the plug at the map sensor (top of throttle body). also check the vacuum lines. as for the white smoke, i know it sounds silly but smell the white smoke. if it smells like coolant it's a head gasket leak. the coolant gets burnt off and exits the tail pipe as steam (white smoke). check your coolant level, your coolant will be low if that is the case.
1 - 13 of 13 Posts
