My 2004 Ody has a steering wheel shake. It turns the wheel left to right. It starts when the van starts to move. Not as noticeable in turns. Above 40mph there is a slight shake.
Wheels have been aligned, balanced and switched front to rear. The rotors are not warped. Struts have been replaced. I replaced the rear engine mount. (not fun) It ssems to have gotten worse. Occasionally there is a spinning sound (bizzip) but only lasts a few seconds and above 45mph. bushings are fine. No apparent bent parts. No CV joint sounds.
From reading the threads I thought the engine mount would be a fix. maybe the front mount is also bad. No signs of leaks on front. What happens when a hub bearing goes bad?
Any ideas would really be appreciated
