I've searched various threads regarding the steering wheel shaking issues at high speed but it seems there could be various factors contributing to the shaking symptom. My Ody has two Yokohama AVID TRZ tires in the front with about 15k miles and no name brand tires in the back with about 50k miles. When the Yokohama tires were mounted in the front, they were balanced at a local shop (They did not have the Road Hunter Balance Machine) and were never rotated with the rear ones.
It had a slight steering wheel shaking when I bought it used with 65k miles (It now has 118k miles) but it was not serious so I kept it as-is. However, I noticed the shaking is pretty bad during a 1k mile road trip last week.
Something to note about the shaking is that the steering wheel shakes ONLY WHEN ACCELERATING above 60~65 MPH and up. When I have my foot off the gas pedal even at the high speed, the shaking goes away.
I'm in need of replacing the rear tires that are almost worn out and I was wondering what I should try first to eliminate the steering wheel shaking issue. Also, when I put the Yokohama tires in the front, I noticed the Yokohama tires were little nosier and louder than the no name brand tires which were in the front (they are in the rear now).
Should I get a pair of new tires to put in the front, get them balanced at a shop with Road Hunter Balance machine first to see if it solves the issue? Should I do the 4-wheel alignment as well? I never done alignment since the ownership, but it never skewed to right or left.
Any inputs or suggestions are welcome!
