Any one experiencing rusted sunroof? In the front corners. 2011 Odyssey EX-L 109,000 miles. Front corners of sunroof frame rusted. Nothing on the roof body is rusted. Have not had any leaking issues and the drains work fine. I replaced it with a salvage one from a 2014 from parts dismantler online. I ts the same part number 2011-2017 Odyssey (Part No.:70200-TK8-A02) so you would think part would be availbale for a three years old 2017 model year.
However, I had no choice but to find a salvage part because the part is currently unavailable and on back order from dealers. I tried 15 different dealers all over the country with same result. None of them had any idea how long the part would take to get from back order. Dealer retail was about $585 plus tax. Some online dealer parts prices less but then shipping costs to add. In any case, I have no rust anywhere else except there. Is this a common issue?
Weird that if you have a 2017 Odyssey and need a sunroof (either because damaged, shattered, rusted), a three year old vehicle, that you can't get a part for it. Is there a run on that part? I was able to get a very nce condition one for less than $300 including shipping.
Picks of the rusted corners of mine here. After I reoved it and peeled back the seal further I discovered the rust was far worse. The metal frame that the glass is bonded to was disentagrating under the seal with rust. There were also flakes of rust in the drain area of the sunroof that had fallen off the frame. Luckiy they did not get into the drain tubes. Vacuumed it all out, then used some trimmer string from my weed wacker and fished it down the front drain tubes as far as I could. Then poured water down them to make sure they were clear. The sunroof is super easy to remove and replace. There are four T-25 bolts that secure it. There is some room for adjustment so it seals correctly and is level. So take your time putting it back in. Do not torque down on those bolts to hard. If you strip them out, yout life will get very complicated. Took lots of trial and error adjusting and oepening closing sunroof to check fitment and no binding. Have some minor adjustements still to do. There is a black plastic trim cover that hides those bolts, one on each side, but you just pull them off to access the bolts. It helps to put the sunroof with the back popped up position in order to access bolts. Recommend having an extra pair of hands to remove.
Also the seal is never 100% leak proof. But there are drip catch channels built in to the sunroof frame that channel water to the four drains, two in front that you can see, and two in the back that you can't see becasue they are way back on the frame which is hidden by headliner. The two in the front corners can be seen using flashlight and standing between front seat with your head up through the sunroof opening. It takes some searching but they are there. Drain tubes connect to those and run down behind the side pillars where they eventually exit at bottom behind front fenders.
