So I saved a bunch of money doing struts & sway bar links awhile back but I nicked the sway bar when cutting off the stabilizer end link with my Dremel. Booooo.
Found the OEM at Bernardi for $80 and want to have it done right (and before the new end links get stuck on there like the others did after a bunch of miles).
That said, if I disconnect the end link and remove the bracket/bolts where the bushings are held, is that it? Will it just slide out to one side?
If anyone can point me in the direction of a YT video, I'd be forever thankful. Right now I'm stumped because my Google-fu is failing me. "how to replace sway bar on honda odyssey" and all derivatives show only end links/sway bar bushings. Thanks in advance!
