I saw on another thread that the Z1 is discontinued. If I switch over to aftermarket (Z1 compatible), should I do the 3-4x change with the new fluid, or will 1x be okay? I've got a "new to me" 2008 with 28K miles on it, so this will be my first (and probably the van's first) attempt at a fluid change.
This is also probably a dumb question, but do I fill through the dipstick tube? I can't figure that out from other threads. I found one picutre of a refill plug on an older model, but I don't see anything like that on my '08. I've got a B123 service code, and took care of it all (except balancing) myself. Would like to do the ATF myself too if it's not too much of a pain.
Third... Is it really necessary to change the brake fluid every 3 years? I've never changed brake fluid outside of a brake job before.
Thanks.
Thanks.
