Hello,
I'm new to odyclub. After searching through the archives, I'm still stuck.
The tail lights and license plate light don't work. A few days ago they worked (just the right one given that the left bulb was burned out and hadn't been replaced yet.) Here is what I've done so far.
I'm not sure we can afford to keep the van and don't want to spend the money to buy a repair manual with the wiring diagrams unless it's necessary.
Can anyone help with a wiring diagram so I can trace the power?
What else should I try? I'm afraid I've missed something obvious.
Thank you kindly.
- Replaced the left tail/brake light (the brake part at least was bad and now works after replacement)
- Replaced the 15 amp fuse in the #10 slot under the dash on the passenger side, twice just to be sure (though all fuses used in that slot still test good)
- Verified the 40 amp fuse under the hood
- Swapped the two lighting 4-pin relays under the hood close to the 40 amp fuse for the tail lights
- Pressed on every wiring connection I could find that might possibly be related to make sure they are snug
- Failed to find any relays under the dash on the driver's side as directed to by some posts besides the main relay
- Failed to find the 'little black box' relay in the back left jack compartment
- Failed to find any wiring diagrams that relate to the tail/license lights
Thank you kindly.
