Hi, so I recently did the programming of where you set all the doors to unlock when you put the car in park. Since then, the button to open the tailgate inside on the dashboard and the button on the back of the actual tailgate no longer work. Now if I use my key fob outside and press the trunk release it opens up but that's the only way I can get it to open and if I press the button to automatically close the tailgate that's on the actual tailgate it closes. Is there something that happened when I did that programming thing and it messed up?
If I unplug the battery will it reset everything and maybe that'll fix it? I've done a search and read through the forums and I can't see my specific problem and that's why I'm asking
