1 - 20 of 42 Posts
Direct fit... used my factory lug nuts...
Wheels were from a 2016 Tesla Model S 90D
5x120 bolt pattern. 64.1 center bore
Tires are 245/45/19 Michelin Primacy
No spacers or adapters... no rubbing
May be painting them gunmetal grey
156428
156424
156425
2006 Honda Odyssey (EX)
Nice wheels OP. I do think these wheels would look really good on a 4th gen, not as convinced about it on the 3rd gen.
In my opinion the best wheels for the pre-facelift 3rd gen are the 3rd gen non-PAX Touring wheels. But I'm cheap so I tried photo-editing them on, though my skills aren't the greatest :p
156431
Yess I also like the look. Perfectly suited for the 2008 facelift. Wish they were at least 19s!
Eh, I think those wheels were never meant for the facelift. I think the 9 spoke 16" wheels used for the facelift are the best ones for the facelift model, yet to find anything else that works IMO.
Not bad. I feel like that'd really look good if the van was black or some darker color.
It is not whether it fits the wheel well, but if the offset of the wheel matches the Honda wheels.
From Dr. Google:
Wheel offset
Featured snippet from the web
The offset of a wheel is the distance from the hub mounting surface to the center line of the wheel. The wheel offset is measured in millimeters and results in a positive, negative, or zero offset. ... Negative offset is when the hub mounting surface is toward the back or brake side of the wheels centerline.
All, no matter what you do to a 4500 lb box, you're never going to be able to pick up women in it, unless they're moving furniture!
Jejej best comment ever!
Do changing wheel for a 20" for example can have a negative impact on the transmission?.
1 - 20 of 42 Posts
