It wouldn't surprise me if something similar is happening with Honda's software. If so...I wonder if Honda would even address it for a car this old.Microsoft is apparently using signed int32 variable to store the value of a date. This has a maximum value of 2,147,483,647, and security researcher Joseph Roosen mentions (via Bleeping Computer,) dates in the year 2022 have a minimum value of 2,201,010,001 or larger
Is it a DeLorean Odyssey?my odyssey changed the year from 2021 to 2002
Welcome to the new world.and today all got messed up
You do not need to remove the disk.2008 - EX-L, not sure what version my cd is... couldn't figure out how to get it out. LoL...Press the open button on the unit under the seat... But nothing happen.
NOTES
This 2021 Map Update will be the final map update release for this system and will be available while supplies last.
Wow. 4.36 huh? That is likely what came with your Oddy. You never updated it?Mine is old. 2008 Touring,SW 1.66.00, DB 4.36, US. Display now shows 7:16 Jan 1, 2002 Clock 10:16.
I tried to adjust in Setup. I set both Auto lines to Off but still CANNOT adjust clock. Shows 12:00. +/- numbers change but then go back to 12:00 as soon as you stop. Maybe I have to lookup info on how to adjust clock manually. Entire clock is now wrong leave alone the date.
Kaimanson, in Setup, System Information gives you info.
