1 - 8 of 8 Posts
Well I had a check engine light on my 04 van. It has 115K on it. We
had Honda put in a rebuild at 80k under warranty three years ago. There are
no symptoms I can feel right now. The shifts are smooth and maybe on the
soft side, but it does not feel like its slipping. I had the fluid changed at
105. We also have had a heavy duty oil cooler installed when the car was
new. We have towed with it, but much less in the last few years. Just invested a grand into it , including new timing belts...seems to run fine and
we want to keep this car at least until 200k.
I have read lots of tranny threads but still am confused on what to do.
I know I can extend the life with a fluid change now...maybe cleaning solenoids? I am a good wrencher, we race corvettes and have replaced every
major component on these cars over the years. Need some good advice!
P0720 - then troubleshoot the Countershaft Speed Sensor circuit for a short, loose connection, poor ground or bad sensor.
At least it is not the dreaded P0740 code.
The code you have appears to be caused by an electrical circuit problem and not a mechanical problem in the transmission.
Did you just have some work done recently prior to this P0720 code occurring? It may be an intermitment thing too from what I have read on this code. I would still troubleshoot the circuit and sensor before I cleared the code and see if it returns.
P0720 Troubleshooting and location of Output Shaft (Countershaft) Speed Sensor...
1 - 8 of 8 Posts
