1 - 6 of 6 Posts
Thanks. I never remember to pull out the camera. Need to add this to my 220K mile maintenance session!
How many miles on the original one? Also how old is the van?
Also the symptom, was it always in "cold" area? I mean the temperature gauge.
You post lot of good videos. Please post information also like how many miles, how old, symptoms, part details like oem / aftermarket etc . It would be really helpful.
FYI, you do not need to remove the radiator hose off the aluminum neck to replace the thermostat. Just loosen the 2 bolts and move the whole thing to the side then replace the thermostat. If you do remove the radiator hose off the neck, you need to make sure the spring clamp goes back on the exact same position as before, or it will spring a leak.
And for guys operating these vehicles in colder climates the 180 degree F t-stat makes a world of difference when it gets cold out.
1 - 6 of 6 Posts
