Thinking rear valve cover gasket???
429 Views 11 Replies 4 Participants Last post by  OddyseyRaceTeam
Just purchased this 2007 odyssey and discovered a small leak. thinking it is a rear valve cover based on the location of the leak. Top rear driver side of the engine. Is this a plausible diagnosis???
Hand Automotive tire Motor vehicle Hood Automotive design
Automotive fuel system Automotive tire Motor vehicle Hood Gas
1 - 12 of 12 Posts
Yes. Read the 1st post of the VCM Mega-Thread which is at the top of this section. Consensus is to disable it with a "muzzler".
Reactions: bradydq
@bradydq
At this age you do likely need valve cover gaskets if never performed.
That is a big job. They may be leaking, but may not be. More likely, ....
It could also be the rear spool valve as shown in these videos.
This job is easier. I would start here.
Note the second video @ 2:30, there are two gaskets to change while valve out.
Reactions: bradydq
Discussion Starter · #11 ·
Or rear spool valve.
Trim level?
Welcome to the OdyClub
I believe you are corred with t
Thanks that was really helpful, so as far as my situation goes...I think that the leak is coming from the VVT Solenoid (which is part of the VCM system). I will still have to replace the gasket that is leaking there, then probably consider that muzzle to disable the VCM :)
Oh don't be sad, you maybe saving your engine for 100 bux.
1 - 12 of 12 Posts
