Have a 2002 with 113,000 miles on it. About 3 months ago it started making a ticking sound when making a slow steady climb up hill. Tech at Honda recommended starting with higher octane fuel. That didn't help. Had the 100,000 service done with valve adjust. Still ticking. More specifically - ticking occurs when RPM climbs above 2000 (usually around 2200) when the engine is loaded. Will not occur with revving the engine in idle. Tech has essentially checked all his valve work again. They can't find out what is wrong. Now think it might be an exhaust leak but as it doesn't make the sound when just idling they don't know how to find it. Any thoughts?
