I am a new member and thank you all for all the great write ups.
We had an error code on the cam position sensor in January 2020, when I looked at the location, I knew we would need to change the the water pump too to access this part along with the belts. I purchased the parts (cam position sensor from AutoZone) and water pump kit from Ebay (big effing mistake), my friend who is a great mechanic help me change it out and it was done in 6-7 hours.
Fast forward to Sunday 10/11, while driving on the Wantagh State Parkway at 60mph, the car stalled while I was cruising. I pulled over and thought it was the alternator as I just bought a new battery 3 weeks ago. I called a tow truck to pickup the car and brought it back to a local mechanic, here what they are telling me.
1. Need TB and tensioner, TB is broken
2. Replace water pump and flush coolant out
2. Right side motor mound needs replacement
They also said since the TB was broken at 60mph, there is no guarantee the car will be fine/idle correctly and that the valves and pistons could be damaged. I have read numerous threads from this forum about the TB being broken and 99% chance the valves are damaged and will need to be repaired.
I am totally torn, as I bought this car used in 2011 with only 67k on it, and we only drive this vehicle with the kids on road trips. I only drove this for 60k in 9 years.
He said for him to repair the above, the cost is $1,600.00
Questions:
a. What are the chances that I repair the above and the car will be fine?
b. What would be the additional cost if I need to repair the valves?
c. Sounds like it would be cheaper to replace the entire motor, but you could not find an engine with less than 180k.
I am concern this will be a money pit. Please give me your thoughts on what the cost will be for valves repairing? Is it even worth it? Has anyone gone through this?
I am located in Nassau County in New York and would like to get this fixed, however, with the car being 13 years old, I'm thinking it might be time to move on.
Questions:
