I plan on replacing my timing belt in my 2012 Odyssey. What I want to know is what all do I need to replace with it. I’ve seen some post about replacing the water pump at the same time. Do I need to replace the water pump at the same time and what other things need to be replaced during the timing belt replacement? Also I saw in a past post of someone giving detailed instructions but the link was not working, if anyone has that working like I would like to have it.
There's an Aisin kit with the water pump, belt, and tensioner. You can find it on Amazon and Aisin is the brand most recommend on here (and what I just had my job done with here).
