Hi
I am in the process of doing the timing belt(first time ).I really did quite a lot of prep reading many DIY threads etc.
I did the starter "bump"to get CS bolt off and all seems ok so far....except I did not remove old belt yet,I can pretty easily align the camshafts by turning the CS gear, the marks on both cams line up dead on.I am confused about the
the crank alignment,the key is at 12 oclock just like all the pics and I can see the tiny arrow but I notice on the gear a tiny"dimple" at around 4oclock??? Is some thing wrong, should this tiny dimple be lined with the arrow?? if so the gear key would be around 4 oclock position and then cams would be off.
so my big dillema is should that tiny crank gear dimple line with arrow?? I moved the crank a few times and belt does
not look bad and I did not touch the tensioner or idler.
any help GREATLY APPRECIATED.
I just went and bought the haynes book and it does not say anything about crank dimple or key
