Hello everyone, I have about 104K on my Ody and Its time to replace the timing belt. I read through a lot of the threads for the timing belt replacement and as to what needs to be replaces is a little confusing. I have a list so far (see below), can someone confirm this? I am getting a quote for $690 for the T-belt, water pump, and drive belt. Is this fair?
*Camshaft Timing Belt
* Balance Shaft Timing Belt
*Water Pump
* Valve Cover Gasket w/Spark Plug Seals and Grommets
*Camshaft Timing Belt Tensioner Bearing
*Balance Shaft Timing Belt Tensioner Bearing
*Crank Front Oil Seal
*Camshaft Oil Seal
* Balance Shaft Oil Seal
* Balance Shaft Oil Seal Retainer
The Service associate told me to replace the tensioner while doing the service also...is this necessary?
Thanks
*Water Pump
*Camshaft Oil Seal
Thanks
Yes, replace all the seals at the same time, well worth it.
