1 - 2 of 2 Posts
2015 Honda Odyssey Elite.
Keep getting low press light on my tires total of 7 times in approx. 18 months
Dealership request that every month I physically check my air pressure and add
air accordingly. That is not a fix for me! Has anybody run in this issues?
I don’t know if the dealership have exhausted all avenues o fix this problem.
When you get the light do you find a low tire? Is it the same tire each time? I think the Elite will tell you which tire is low, right? If not, then the light means that at least ONE tire is low and you need to check to see which one it is. If it's the same tire each time then get a tire shop to fix the slow leak.
That said, you MUST fill your tires to the pressure listed inside the driver's door when COLD. If you fill them when warm (after driving) then the pressure will actually be too low to start with.
1 - 2 of 2 Posts
