Drain and Fill nowI have a 2012 EXL with 94,000 miles that I don't believe has ever had ATF flushed or replaced.
I took it to a shop and they said they wouldn't flush it if it hadn't been done before at that mileage because they are worried that it might knock things loose inside and create problems with the transmission.
I am not aware of any transmission issues currently although acceleration has been sluggish the last few months.
Is their concern valid? I haven't ever heard this before.
if it looks like a flower of filings on the magnet, youre in for trouble.i have the exact same make and model and recently did a drain and refill. the drain bolt had so much crap on there it was scary to clean off.
mine looked like a bunch of sludge. when i wipe it with paper towel it's not metal or anything.. almost like light bacon fat.if it looks like a flower of filings on the magnet, youre in for trouble.
if it was just black sludge, youre good.
should we drive around first before doing another drain and fill?3x drain and fill now, do another one in 15-30k and keep that up regularly.
Yes, definitely cycle through all of the gears between each drain/fill. They don’t all have to be done on the same day either. Do one each weekend for the next three weekends is an acceptable strategy too.mine looked like a bunch of sludge. when i wipe it with paper towel it's not metal or anything.. almost like light bacon fat.
Yes, that is what the process entails. How much to drive is really up to you. Some like to do it in consecutive days. I think it might be good to spend a Saturday each week doing it for 3 weeks.should we drive around first before doing another drain and fill?
sounds like a plan. goes i'll need to order more maxlife ATF.Yes, definitely cycle through all of the gears between each drain/fill. They don’t all have to be done on the same day either. Do one each weekend for the next three weekends is an acceptable strategy too.
yup we got a tahoe family trip later this month.. so figure i'd best get another couple rounds of flush done before then.Yes, that is what the process entails. How much to drive is really up to you. Some like to do it in consecutive days. I think it might be good to spend a Saturday each week doing it for 3 weeks.
Our cars are so finicky when it comes to fluids and additives that I wouldn't attempt to clean the trans with any additive. I have used the lanolin based engine & trans cleaner in the past on other makes, successfully, but I would never dose a honda. Just listen to the great advice these guys gave you. Would also change the secret trans filter, I just did at 45k miles.I have a 2012 EXL with 94,000 miles that I don't believe has ever had ATF flushed or replaced.
Yes, a few days or a week or two depends on your day-to-day. in my case I am on the highway every morning M-F to work and again back home. so if you are local dive a bit longer or make a few highway runs to make sure you move that fluid around to get a really good mix before you drain a second time Ect...mine looked like a bunch of sludge. when i wipe it with paper towel it's not metal or anything.. almost like light bacon fat.
yea wifey usually use it to shuttle kiddos around, so some freeway driving once a week. since gas is crazy high in CA, we try not to drive too much.Yes, a few days or a week or two depends on your day-to-day. in my case I am on the highway every morning M-F to work and again back home. so if you are local dive a bit longer or make a few highway runs to make sure you move that fluid around to get a really good mix before you drain a second time Ect...
I totally understand what you mean, and yes gas in CA, is crazy. Try to find a Costco in your area, they should have the cheapest gas.yea wifey usually use it to shuttle kiddos around, so some freeway driving once a week. since gas is crazy high in CA, we try not to drive too much.
