First time poster here :) 291k miles on my 2001 "beater van" and the water pump seal has started leaking bad.
I'm planning to get the AISIN TKH001 TB kit from rockauto > More Information for AISIN TKH001
and was hoping to find a list of all the torque specs when putting it all back together. I've run across a couple threads in here with values and images, but none for the 99-04 so far. I'm probably just not using the right keywords for my search.
Thanks in advance!
[edit] looks like I needed to be looking in the maintenance forum vs generation forum. Found this http://www.pontiacpower.org/odysseytimingbelt.pdf which appears to have what I need.
since nobody replied, and it is easily searchable here on the countless timing belt threads...
Except you linked to the 4th gen not 2nd gen.
