From what I have read, the '02 hitch is the same as the '01 hitch, and it bolts up just the same. The '02 bumper may come with the hole already in it for the wiring, whilst the '01 bumper requires you to cut out the hole. However, in the tech section see pics showing that you can feed the wiring harness down behind the taillight without even removing or cutting the rear bumper.
The add-on transmission cooler is the same, but the existing power steering cooler is replaced with a new heavy duty unit.
bolts for Trailer Hitch...
I am having trouble using the 12mm X 1.25 bolts that are supposed to go into the chassis frame...
I know there is rust in there..but I think this is more resistance then rust would cause...
anybody confirm the size of the bolts..?
