I have a '07 EX-L with an aftermarket hitch installed, but no wiring. I am looking at installing an aftermarket wiring harness, not sure which one is better. The prices are the same, and the only difference that I can tell is that the Curt has the ground wire set in the plug, and the etrailer has a separate ground that you attach to the frame with a screw. Anyone know which is better?
http://www.amazon.com/Curt-Manufacturing-56007-T-Connector/dp/B001GMX99K
http://www.etrailer.com/t1-2007_Honda_Odyssey.htm
Thanks!
Tim
I have one for an 06 from Etrailer.. also with a screw attached ground. They had an install video that sold me. I have not put it on yet. Still sorting out which AT cooler to use...your cooler choice ?
Was thinking about something from etrailer, but I need to check back with the dealership. I was there getting my brake recall done, and asked them to call me with a quote for an ATF cooler installed. They called my house before I got home, and told my wife $75 installed, doesn't sound right to me.
The video from etrailer should work the same for the Curt adapter.
