Howdy All,
I have done my share of keyword search and unfortunately it appears not to be obvious to me. Is there a post doing a first gen Ody trans filter and fluid change along with cleaning out the other filters that cause hard shifting?
Any help appreciated...
No filter to change. The screens are on the little solenoids that bolt to the transmission case. They are on the front/lower front (easily visible) and are about the size of two C cell batteries. I use the valvoline maxlife fluid, although many recommend the honda fluid. It's simply a drain/refill/run X 3 procedure. One drain is about 2.8 quarts, so you need about 9 to do a total flush. The trans drain plug has a 3/8" (ratchet) square opening for very easy removal. Buy some extra crush washers at the dealer. My recommendation is to drain/fill X 1 the trans every oil change.
