Are you checking with the vehicle on a flat, level surface with the engine warm but not running?
YesAre you checking with the vehicle on a flat, level surface with the engine warm but not running?
Interestingly enough I did try to do that. I drained it and then poured a quart and filled that quart with the old stuff, and so on. On the last bottle I overfilled the old stuff in the empty quart and I judged it, and then the bolt loosened and leaked some of the new stuff. So I added slightly more. I did a lot of guess work because of the bolt and overfilling the bottle and must have overshot a little.Next time, replace only the same amount as was drained (adding for underfill or subtracting for overfill). It's a lot easier to add a bit more if needed than to remove a bit if it goes over.
Agreed.It will probably be okay.
