I will try and make this as concise as possible. 2000 Odyssey, 110K mi, original transmission, always serviced per recommended interval. My wife complained transmission was shifting harshly about the time I discovered this forum. Never any slipping, burnt fluid or similar issues. Found Jofei’s post about replacing the
TORQUE CONVERTER CLUTCH
SOLENOID VALVE/SHIFT SOLENOID VALVE A Oring/screens and the tubes under the A/T CLUTCH PRESSURE
CONTROL SOLENOID
VALVE A and B and did the work.
I also changed the transmission fluid (completely) and installed a cooler and Magnifine filter.
All the tubes were absolutely clean but the round screen in the TORQUE CONVERTER CLUTCH SOLENOID VALVE/SHIFT SOLENOID VALVE A Oring was completely plugged. Oval screen clean. Not sure which solenoid the round screen is. After the work transmission felt absolutely perfect. Drove for a week with no problem. Yesterday my wife informed me “she barely made it home”
And there were “all kinds of flashing lights and tiny numbers/letters” on the dash. I started it up and the check engine light was on but nothing else. I had no way to read the codes so I cleared them by pulling the fuse for a fresh analysis. Check engine light now off and everything appeared normal. We live in a rural, hilly area so I had back roads of various terrains to test. Drove in 1 just fine. Put in 2 and drove just fine for quite a while up steep hills(at the appropriate speed for the gear with no slipping or abnormalities). Then for no apparent reason in 2 engine suddenly sped up as if it were put in N. After taking my foot off the gas pedal and coasting to a stop I put it in 1 and it harshly shifted into 1. This happened twice while driving for about 20 min. Each time was the same-it just felt as if it were put in N-not slipping-and then harshly shifted into 1. Then I went into D4 and drove to the freeway. Perfect through all the gears and lockup. I got on and off the freeway 4 or 5 times and was perfect every time. I drove around for an hour in city traffic and problem never happened again. Very concerned to let my wife drive it. Manual says possible shift solenoid valve A.
I did not pull the screens again-it’s quite a job to get to them.
Checked fluid and it looks and smells new.
Any ideas appreciated.
Tony
:huh:
CONTROL SOLENOID
Tony
:huh:
