1 - 7 of 7 Posts
I've read pretty much everything on the 99-2002 transmission recalls & issues, so, I don't fall under that category but, my '99 now has 240K miles on the original trans and it exhibits the following:
When cold, it has a difficult time shifting into 2nd...it "slides" in if I back off on the throttle a bit when it starts to shift.... 3rd is a hard shift "clunk:.
After about 10 minutes of warmup.. it shifts beautifully, all day long...up or down.
It's been doing this for about 6 months with no apparent worsening.
Fluid is Honda and has about 15K on it.... I had a drive axle leak prior to that and must have put 12 quarts of ATF thru it before replacing the seal.. so.. its been flushed pretty well.
I know with 240,000 miles on the orig trans it probably "deserves" accolades as well as a rebuild but, I'd like to keep it going till it breaks.... is this shifting issue fixable with sensors?....I show no codes at all ever, for transmission issues.
Thanks a bunch...
Dave.
Dave, can you post here with your result? I have something very similar going on. '99 with original trans, 143k miles. I'm have the following symptoms:
- when engine is cold, it isn't able to get into 2nd. when i back off on throttle it sometimes gets there. after just a few minutes (less than 5), it gets better and drives normally.
- sometimes if i do not back off on the throttle and am heavier on the throttle, it is able to get into second, after a few second high rev flare.
And if you're doing the replacement yourself, and have any pics to share that may help me through the process, pls do!
Gary
Does anyone in the Bay Area (prefer south bay, i.e. San Jose, CA area) have a recommendation for a transmission shop that is competent in doing the right thing with a failing 1999 Odyssey transmission? I describe my symptoms above.
1 - 7 of 7 Posts
