I copied the below text from Honda's Accura MDX site. Will the 2002 Odyssey have both a transmission AND a steering fluid cooler as part of the towing package? A new "factory engineered" trailer hitch (no buying direct form Draw-Tite)? Will any of the '01 parts fit the '02 model? Any comments?
In support of safe towing, MDX's tow hitch and other hardware needed for the job is factory engineered for dealer installation. A standard automatic transmission cooler built into the radiator is adequate for towing up to 2000 pounds. For heavier loads, the addition of a second external transmission cooler and a separate power-steering fluid cooler is required. The dealer-installed trailer hitch is a Class III receiver-type design that bolts on with no drilling, cutting, or bumper-cover modifications. A harness to provide electrical power to trailer lights plugs into a connector provided at the rear of the vehicle.
