Hello everyone. I’ve been reading a couple threads and I seen ppl mentioning trans updates from Honda. What exactly is it that leads to that? What should I look for? and is it something that I should do for precautions?
So in other word pointless to get the update if I don’t have any judder.Torque converter judder caused by prematurely worn ATF. Software update prevents the ATF from wearing prematurely in the future, the 3x drain and fill gets the worn ATF out of there.
Ask a dealer about it, if your vehicle needs it they can do it.
I wouldn't say it's pointless. If your vehicle is covered (which doesn't last forever, I believe it's something like 8 years/80k) it's worth getting it done. A headache you won't have to deal with.So in other word pointless to get the update if I don’t have any judder.
It's not pointless, just not necessarily job number one on the priority list.So in other word pointless to get the update if I don’t have any judder.
Are we talking about this bulletin? If so, its not about stopping ATF from premature wear (only way to do that is keep it in Honda bottle), but about reprogramming TC lock up clutch.Torque converter judder caused by prematurely worn ATF. Software update prevents the ATF from wearing prematurely in the future, the 3x drain and fill gets the worn ATF out of there.
From what I understood about the update, the TC lock up clutch is what was causing the ATF to wear prematurely, and this wear is what caused the judder (which is why people who are very religious about changing their ATF usually never saw this issue). The update changes the TC lock up clutch behavior to prevent the wear from occurring. This is also why the bulletin states to replace the transmission fluid.Are we talking about this bulletin? If so, its not about stopping ATF from premature wear (only way to do that is keep it in Honda bottle), but about reprogramming TC lock up clutch.
Exactly. Basically, they are bumping up the pressure on the torque converter lockup to make it more aggressive - the judder is a slip that will wear/shear the trans fluid much faster than a fully open or fully locked converter. Likely they originally programmed it to be 'soft' so that your average soccer mom would love the 'smooth' feeling of the transmission...ok, I found a similar bulletin, that actually has an exact explanation of the issue
That doesn't seem like a bad thing - it will get the transmission pump going faster and get the trans ready for operation sooner. All gears should be disengaged, so it won't do anything other than drive the input shaft on the trans.Amazingly, the TCC is locked up when you start your engine, and when line pressure is sufficient (usually pretty instantly), it's opened (i.e., in a disengaged state).
