Hi All,
I recently bought Honda Odyssey 2008 Lx from dealer and it has 23K mileage, Basic warranty expired. It has only the Power train warranty. My odyssey is giving Clunking/ Clicking While Turning right and left side. When I do the search on the odyssey forum that there is TSB(TSB 10-042) for this and gave the details to fix this.
PROBABLE CAUSE
The outer CV joints are faulty.
CORRECTIVE ACTION
Replace the driveshaft assembly.
TSB 10-042 Clunking, Popping, or Clicking While Turning
Applies To: 2007–09 Odyssey – ALL
2010 Odyssey – From VIN 5FNRL3...AB000001 thru 5FNRL3...AB028891
http://www.urvi.net/forumfiles/SB/A10-042.PDF
I understand form the details that Drive shaft has worn out and need to replace the for Left and tight drive shaft.
Please let me know if the drive shaft replacement covers under power train warranty.
If not above, will this cover by my extended Honda care and cover below items
Drive Axle System
(front or rear)
o Drive Lines
o Constant Velocity Joints and Boots
o Hub Bearings
o Axle Bearings
o Seals/Gaskets for the above stated parts
Please, please, please let me know if any one has any idea or suggestion.
PROBABLE CAUSE
CORRECTIVE ACTION
Drive Axle System
(front or rear)
o Drive Lines
o Hub Bearings
o Axle Bearings
