I was driving my van and it lost power and died shortly afterwards. It restarted and I was able to drive it home. Since then it won't start. It turns over but won't start. I checked the fuses under the hood and the fuses inside the van. Everything seemed to be in good working order. So I got a new "main fuel relay switch", I plugged it in and there was no change when I tried to start it. So I thought it was my fuel pump since I couldn't hear it turning on when I would try to start the van. I replaced it. Still no change. I am about to change the fuel filter because I changed to fuel pump, but I don't have any hope that this will fix the problem. I have heard that it could also be an ignition switch or is it something else? Any help would be greatly appreciated!
if it turns over you can check to see if ignition switch is working by doing this
turn switch on all the way ///let it keep cranking and put it in drive while holding the brakes and with ignition switch all the way turned still.
