I got a set of Rockford Fosgate Fanatic P's for my Ody ... and they fit w/o any mods. Sounds great. Of course ... there's a little issue of the tweeters. They're not in just yet.
Now, I'd like to replace the existing ones up front in the dash. Rockford et. al. insist (quite adamantly) that I use their crossovers if I'm going to do that. Don't just use a capacitor. OK, fine.
Now, um, exactly WHERE is the signal split to the door-and-dash? Right, just as I suspected. Probably can't get to it easily, right? It certainly isn't in the door well - or at least I didn't find it. Anyone?
So that leaves ... ugh, running new wire from the door up to the dash, disconnecting the existing tweeter, capping off the line (leaving it there) and placing the crossover on or within the door (provided the window doesn't get in the way). Tell me, someone, anyone, is this the ONLY way to pull this off? Has anyone actually done it?
The rear speakers are another issue since I want the sound of the components but want it to be as stealth an install as possible. (Couldn't find any RF coaxials that would fit.)
Now, the RF tweets come with three different mounts, one of which is a wedge that can be surface mounted (hmm, perhaps with velcro ... or does that have folks shouting sacrilege? heh-heh.) Has anyone installed component tweets in the rear of the Ody?
Clues welcome ... !
- JD
Clues welcome ... !
- JD
