1 - 6 of 6 Posts
I had inquired earlier if our Gen 4s had the transmission temperature at the OBDII port and could not confirm until I found this earlier thread from 2014 to 2016 in which ninjafish said his UG MX V1.3 did display his Ody's trans temp.
Thread on Ody forum confirming that UltraGauge MX 1.3 did have transmission temp for a 2011 Ody so I assume the v1.4 would also. Confirmed: Ultragauge MX does display transmission...
So I ordered a new UG MX with the Honda preprogramming for my 2011 Touring Elite which arrived today. I connected it and set the fuel tank size to 21 gallons and the engine size to 3.5 liters.
Handwriting Gadget Output device Font Display device
Then I set up gauge page #2 to display all of the eight M Gauges in order and every one showed “Err” for error. None of them would display a value with engine running or not running.
Vehicle Motor vehicle Gadget Communication Device Car
Thar previous thread also had this comment from Stone_wen:
"I purchased a UG MX1.3 with Honda CAN pre-config as you did, I have a 2012 Odyssey EX-L, however the read out is all error. I contacted ultragauge, believing they pre-config with a 2008 odyssey codes. "
There was no follow up from Stone_wen to say if UG solved his problem but there was this from dmfrey1:
"Just installed an UltraGauge MX 1.3 and it supports transmission temp out of the box for my 2010 Odyssey. Couldn't find verification before purchasing it, so I'm adding it to the "supported list" "
This is the M Gauge setup page as supplied for transmission temp in degrees F and some of the numbers are different than one photo in that earlier thread for transmission temp on a Toyota Tacoma.
Communication Device Output device Portable communications device Gadget Mobile device
Anyone have suggestions on how to get this MX v1.4 to display the eight M gauges on my 2011 Touring?
If Stone_wen is still around, did you ever get your UG MX v1.3 to read the M Gauges?
Discussion Starter · #2 ·
Update:
I plugged the UG MX into our 2010 Odyssey Touring and all of the M Gauges did display for it. The AC PSI read 0 and remained 0 when I turned the temperature to Lo, but the other M Gauges seemed to read realistic values. The UG says both Odysseys use 29 bit CAN, so why the UG codes work for the 2010 and not the 2011 I have no idea.
I had this reply from UG:
If a Mgauge shows "Err", it means that the underlying code is not recognized by your vehicle.
According to your order, you selected, - Preprogramming Option: Honda with CAN, which is correct and is the only option for Honda
There are a few other known Honda codes for trans temp:
TDATA: 00EF222201
TCTRL: 93
MTCH: 240000
RPOS: 1808
RCTRL: 10
Left/Right: 30
X:0001
/:0001
+:FFD8
Output Format: 10
Alternate:
Same as above except:
TDATA: 00EF223083
MTCH: 220000
RPOS: 2808
I really wanted the M Gauges for my 2011 with the tow package to keep track of the trans temp and also to keep track of the alternator which often drops out on startup but recovers and then seems to charge OK. I am going to run the UG for awhile on the 2010 to track its alternator because the battery has gone flat twice recently when it was parked for 4 to 5 days.
its supposed to work. did you open a support request with ULTRAguage?
Edit: This post sheds some light on the subject, it only works with the 5 speed, the 2010 has the 5 speed, the 2011-2013 ody non touring have the same 5 speed.
2011-2013 touring has the 6 speed.
its supposed to work. did you open a support request with scanguage?
Did you mean UltraGauge? Or ScanGauge? The reply above was from UG support and I replied and got a follow up that didn't help.
My reply: 5/6/22 16:31
OK, I'll try the alternate transmission temp codes. Do you have any other codes for the alternator amps and the ECM volts? BTW, would resetting the gauges in Gauge setup restore the M Gauges to the preprogrammed codes?
UG reply: 5/6/22 19:06
The restore works on everything but the Mgauges.
We only have the 3 codes provided beyond those pre-programmed.
Best regards, Steve
UltraGauge Support
UltraGauge OBDII Scan tool and Information Center
I didn't get that other thread to open so far, but I'll keep trying
So... the reports that the M Gauges did work on Gen 4s were from folks with the 5 speed transmission? I wonder why Honda would change ALL the codes for the 6 speed models, but then why did they omit the individual tire pressures for Gen 4 and restore that feature for Gen 5? Seems no rhyme or reason. I'll try re-programming the Trans Temp degrees C gauge to the alternate F degree codes and see if either of them work for either Ody, but I don't have much confidence.
If anyone has UG codes that work for a 6 speed Gen 4 I'd appreciate hearing from you.
2011 Odyssey LX, 120k miles
I don't know anything about the ultragauge or scangauge.
I have a 2011 LX (5-speed).
Earlier today, I plugged in my Foxwell NT520Pro OBD2 reader. Remembering this thread, I searched through the OBD2 section (where the tool works as a generic OBD2 reader) and could not see ATF temp anywhere.
Then I used the Foxwell Honda software, and using that was able to see ATF temp, presented in two separate fields, both as a Voltage (V) and temperature (*F).
So if there was any doubt, at least on my 2011 LX, there is an ATF temp sensor, and its value is in some computer somewhere, just needing to be read correctly.
I inquired with support for my 2011 TE, and they would not commit to an answer which is why I went with scanguageii.
all the posts that say its compatible, are ones for non touring 5 speed units.
I do like the display on the ultraguage ,but clearly they dont care much about evolving the product for Honda's.
1 - 6 of 6 Posts
